91 L98 starts, surges a few times, dies.
If I try to keep the engine running with the gas pedal, it will keep surging, tries really hard to stall when the RPM crashes down.
Here is a video of what happens:
it's an 85 Trans Am with a 91 swapped in. Dyno Don built the engine last year. Very low miles. Thoughts?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 91 L98 starts, surges a few times, dies.
What’s your fuel pressure at ?
Well it's been towed to a shop, so I won't be able to check today. Whether some Joe schmo shop is going to be able to figure it out, I don't know. Some shops can't figure out "older" cars. I will look into it they don't figure it out.
That said, fuel pump is new (less than a year), injectors are the same. Whatever that's worth.
