Throttle Position Sensor Calibration
Car: 1986 IROC-Z
Engine: 90-95 ZZ4 Crate 350 TPI
Transmission: 700R4 4spd Automatic
Axle/Gears: 3:73
1986 Camaro IROC-Z (MAF) 350 TPI with .502 cam and 58mm Throttle body from TPIS. Do you have a chronological sequence for adjusting the TPS
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Throttle Position Sensor Calibration
Set the min idle speed before you set the tps voltage
http://chevythunder.com/do_it_yourse...ation_page.htm
91_RS_Brazil
Dec 28, 2016 08:08 PM
Bald_eagle_machine
Oct 26, 2016 11:25 PM
