line delete
Old Dec 3, 2017 | 11:11 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
line delete
being my car is FAR from stock and my charcoal canister is gone, for those of you on this side of the modded fence what have you done with the metal line that goes to the tank from the canister?
Old Dec 4, 2017 | 08:24 PM
NoEmissions84TA's Avatar
Re: line delete
You cannot just put a vacuum cap on it because your fuel tank will then have venting problems,
Old Dec 4, 2017 | 08:32 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Since the sender is out I'm going to cut the line and ither solder it or tap it with a weld to seal it up.
Had an afterthought and dropped Tibo a line and he told me what I mentioned above.
Sent from my electronic leash.
