Cruise Control Vacum lines
Old Jan 28, 2018 | 03:59 PM
aseychell's Avatar
Car: 1988 Trans AM GTA
Axle/Gears: 9-Bolt 3.27
Hi
Am currently reinstalling my cruise control on my 87 GTA and found a lot of diagrams which show the vacum hose from the T-Piece in the plenum (also leading to the HVAC) to y going to the cruise control servo and reservoir ball.
All is fine so far but what goes to the second hole on the servo? Looks like it takes 2x vacum hoses but all the diagrams show only 1.
Old Jan 28, 2018 | 04:21 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: Cruise Control Vacum lines
Goes to the switch on the brake pedal to release the vacuum when you hit the brakes.
Old Jan 28, 2018 | 11:41 PM
aseychell's Avatar
So it is also a vacum pipe? I thought what goes to the brake switch is a wire not a pipe. Will take a look at the brake pedal then.
Old Jan 29, 2018 | 09:23 AM
daferris's Avatar
The brake pedal has both a electrical disconnect for the cruise but also a safety override vacuum release in case for some reason the electrical release fails.
Old Jan 29, 2018 | 03:39 PM
aseychell's Avatar
Understood. I went to take a quick look at the pedal and it does actually have this hose.
Thanks for all the information guys. Much appreciated
mmadden55
Oct 21, 2009 06:17 PM
SAEspinz80
Feb 18, 2002 01:26 AM
rscamaro91
Aug 13, 2001 08:41 PM
pookey
Jul 7, 2001 10:43 PM
pookey
May 8, 2001 11:19 AM
