89 1500 4.3efi to 5.7tpi out of 88 camero
Old Apr 25, 2018 | 08:17 PM
Dave DesJardins's Avatar
Hi I have an 89 Chevy 1500 with a 4.3 EFI and I want to put my motor out of a 88 Chevy camero it’s a 5.7TPI what is interchangeable and what will I need to change around I got the new computer and a painless harness. Will I need to change the motor mounts or frame mounts? Anything is helpful
Old Apr 25, 2018 | 10:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 1500 4.3efi to 5.7tpi out of 88 camero
Camaro ! , You might have better luck on a truck forum to find the differences between the mount location on the 4.3 vs 5.7l . Or just measure from the bellhousing to the mount.
For the harness you can rework the harness to speed density tpi and use a 1227730 ecm. You also need a high pressure fuel pump for the swap.
Old Apr 25, 2018 | 10:29 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
I say put the 350 and ur favorite transmission behind it. Then do what I did to modify TBI wiring and ECM
http://www.gmt400.com/threads/tbi-to...on-mpfi.39486/
There are slight differences because of the year (95 vs your 89) and different computer. These guys can explain the difference in the V6 and V8 ECM in the trucks if there even is one:
http://www.gearhead-efi.com/Fuel-Inj...GM-EFI-Systems
Old Apr 25, 2018 | 10:31 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Camaro !
Listen to people in canada pronounce it come-are-oh, its weird. But I guess they get the right since they built them up there for a while.
the0311marine
Mar 9, 2010 07:24 PM
89irocz355
71
Mar 5, 2010 04:43 PM
89irocz355
Mar 18, 2008 02:49 PM
tpi-hearse
Dec 13, 2006 09:57 AM
Blockhead
Jan 7, 2002 04:53 PM
