Grumpy's TPI vs MSR vs HSR dyno runs
Old Feb 19, 2020 | 03:20 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Just found this. FYI. Interesting.
https://www.corvetteactioncenter.com...tealthram.html
Old Feb 19, 2020 | 07:31 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Grumpy's TPI vs MSR vs HSR dyno runs
Its interesting to see how much more top end the HSR had. Most shootouts show the Miniram on the right side of the chart with all the top end power.
EDIT: if you follow the thread and links down, he came back and posted that the Mini-ram was having a oil leak and was causing knock and other issues. So the Mini-ram dyno is useless for comparison.
Old Feb 19, 2020 | 09:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Blast from the past. This info was posted here alot, original tester i believe was a member here although i forget the name
Old Feb 19, 2020 | 09:25 PM
NoEmissions84TA's Avatar
Since Grumpy's got mentioned, David Vizard joined Grumpy's last week.
http://garage.grumpysperformance.com...resting.15909/
86White_T/A305
Alternative Port EFI Intakes
22
Aug 12, 2009 01:12 PM
89IROCZZ4
Sep 10, 2007 07:31 AM
transamice
Sep 7, 2006 04:06 PM
c4boom
Mar 16, 2003 03:03 PM
