Best TB, Edelbrock, Holley, or BBK. Need advice.
Old Jan 15, 2002 | 03:53 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I'm looking into Throttle Bodies for my upcoming engine build up. I'm building a 385 Super Rammed motor and am looking for a 58mm TB. I just want to know about experiences and opinions on these three or any others that are good. Thanks
Old Jan 15, 2002 | 04:42 PM
Guest
Guest
Posts: n/a
I have a BBK sitting at home. It has sort of a built in airfoil, but I think they could have done a better job of casting/machining it. I spent a couple hours cleaning it up. Also I enlarged one of the spot faced areas where the lower bolts are, it was slightly offset of the hole and my ARP bolts wouldnt fit in the recess. The bolts they supply fit fine though.
Aside of that, it seems like a pretty good piece.
Old Jan 15, 2002 | 05:53 PM
91-ZZ4-Z28's Avatar
I have an Accel billet 58mm and it is very high quality.
Old Jan 15, 2002 | 08:16 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I have the 58mm BBK on my car...I Havent had any problems with it. Just go easy with the small screws holding the Idle air motor piece on. If you are not careful its easy to strip or cross thread one. IMO I would buy the cheapest one.
Old Jan 15, 2002 | 08:41 PM
JR4444's Avatar
I like my Accel one. I believe that some flow 1000 CFM and others flow 1050 CFM. That would be the only major difference in them.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Royal_Z
Sep 30, 2015 08:45 PM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Night rider327
Sep 25, 2015 04:47 AM
