Fuel pressure drop while cranking
Old Apr 26, 2021 | 10:33 PM
Undertow's Avatar
Car: 1991 Camaro Z28
Engine: 5.7l TPI
I'm experiencing hard cold starts.
Is the fuel pressure supposed to drop while cranking? If not, what causes this?
The Fuel pump primes to about 38 psi, and holds, but drops to 10ish psi when cranking. It seems to do it in relation to the drop in battery voltage. When the car starts, it jumps up to 40-42psi and holds.
Old Apr 27, 2021 | 07:26 AM
Vader's Avatar
Re: Fuel pressure drop while cranking
You're on it - Fuel pressure is affected by pump voltage. Is the battery voltage dropping below 10V during cranking? Regardless, 10 PSI seems extremely low. I would be wondering about circuit resistance including connectors, relay contacts, and grounds.
Cambridge205
May 27, 2008 09:13 PM
Benm109
Oct 16, 2004 05:25 AM
z 28 jari
Jul 16, 2003 01:28 AM
Dragroc
Sep 24, 2002 04:35 PM
