Stalling after intake manifold installation
Old Jun 24, 2021 | 06:13 PM
Ironmike77's Avatar
Hey guys having an issue with my 91 Camaro 5.0 TPI. Just recently got my lower intake manifold replaced with a new one. Because it was leaking coolant. Anyways now as I’m braking or slowing down my car idles up and down, eventually dying out sometimes on me. Thought maybe it’s a brake booster issue? Hear a hissing sound as I press the brake pedal, saw videos where that could be a problem. Any help would be great.
https://youtube.com/shorts/dTmJridC2fc?feature=share https://youtube.com/shorts/9jx2rRqmpic?feature=share
Old Jun 24, 2021 | 07:25 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Stalling after intake manifold installation
Vacuum leak most likely. You can fiddle around with brake cleaner and hope you find the leak or use a smoke machine (you can even make a diy one) to for sure find your leak. Mega common on tpi where there is 100 places to potentially leak. Good chance the gaskets on the lower were put on the wrong side.
Old Jun 24, 2021 | 07:32 PM
Ironmike77's Avatar
I really hope he didn’t mix up the gaskets. I’ll have to end up bringing it back to him. With brake cleaner, I just spray around the engine until I hear it bog down?
Old Jun 24, 2021 | 07:46 PM
IF the brake cleaner is sucked into the leak then you will hear a fairly clear change in engine speed. If the gaskets are on the wrong side then it won't be hard to find that in particular. But vacuum leaks can easily hide on tpi so it's hard to spray all the places and then you're hoping the leak is strong enough there to pull in the brake cleaner. I've even sprayed places that I knew leaked and didn't get a change in engine speed. I find it very ineffective. Kinda like playing the game Risk using darts partially blindfolded. A smoke machine will show you where your leak or leakS are.
Old Jun 24, 2021 | 07:51 PM
Ironmike77's Avatar
Can a bad brake booster cause these issues. Because when I press the brake pedal it causes a loud hissing. Also as I brake while driving, the pedal feels really soft than drops like 2 inches and finally becomes firm.
Old Jun 24, 2021 | 09:26 PM
A booster can leak vacuum, absolutely. Not too likely but very possible. Easy to test. Disconnect the vacuum line from the intake and cap it. Does the idle and running come back to normal? Note: DO NOT DRIVE while in the condition. While I assume you'd know that, one can never be sure.
Old Jun 24, 2021 | 09:48 PM
Ironmike77's Avatar
🤣🤣 of course! I’ll definitely check that out though, thanks!
brandoo
Oct 18, 2011 10:38 AM
Shadygrady
Jun 2, 2006 10:22 PM
Sauron91
Jan 15, 2002 02:51 AM
