Tall valve cover clearance
Old Jun 26, 2022 | 12:25 AM
TheMagikMan's Avatar
Car: 1986 Firebird Trans Am WS6
Engine: Cammed 358 TPI
Transmission: Built 700r4
Axle/Gears: 2.77 Borg-Warner 9 Bolt
My 305 spun a bearing so I'm swapping in a slightly built 350 and migrating the TPI, and along with that I would like to use a set of tall milodon valve covers I have laying around and was wondering if they would clear the serpentine and TPI on an 86 with AC.
Old Jul 22, 2022 | 05:51 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: Tall valve cover clearance
I have a 350 TPI with serpentine in my 87 Monte Carlo SS. I too wanted to get tall valve covers but it appears the alternator stud will hit the corner of the DS valve clover. With the aftermarket heads, with taller valve cover rails and thick gaskets, the alternator stud is pretty close now. I put a plastic thing over it. I could clock the alternator to move the stud away from the valve cover but I would lose the support connection at the bottom rear. Good luck.
Fred SS
luvofjah
Oct 14, 2021 08:25 PM
SRKLEGIN
Aug 23, 2013 02:08 PM
TraviZ
Aug 5, 2013 03:53 PM
ks71z28
Feb 15, 2005 10:41 PM
