Using PTFE fuel line on TPI flex lines under hood
Old Sep 6, 2023 | 07:51 AM
m300slr's Avatar
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
Hey,
Im wondering if its ok to use PTFE under the hood for the supply and return lines to the engine. I understand theses are a great modern line but will they hold up to the movement\vibration of the engine? Has anyone done this?
Thanks!
Old Sep 6, 2023 | 08:23 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Using PTFE fuel line on TPI flex lines under hood
They will work just fine. I even use them for my power steering lines.
Old Sep 6, 2023 | 08:31 AM
ULTM8Z's Avatar
Been running Aeroquip braided teflon lines from tank to rails (supply and return) since 2006.
Before that, I had been running Earls braided rubber and had been battling a fuel-like odor in the garage for years before I figured out that it was permeating through the rubber.
https://nastyz28.com/threads/earls-b...l-vapor.72426/
I also covered them in heat shield wrap whenever they got anywhere near exhaust.
But, not one single issue or problem in ~17 years now.
I also stress relieved the connections at the fuel rail by putting a bracket on the valve cover to secure them.
Old Sep 6, 2023 | 03:37 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Braided PTFE is ideal for fuel, even moreso if alcohol is in it. They don't flex as much as a rubber hose but they do flex so just accomodate your bends more carefully with the fittings from the start and ensure they have gentle arcs to their destination.
If flexing/weight is a concern, give them a bracket so all the tension isn't resting on the fitting. In any case, braided PTFE is my choice for flexible fuel lines and I would recommend it to others. I use Evil Energy kits and so far haven't had a single failure that wasn't operator error. PTFE lines are slightly more annoying to assemble when it comes to getting the right amount of the braiding unraveled to let the ferrule seat in correctly, but if you do mess one up, they can be disassembled and reused usually.
I also prefer using a death wheel / cut off disc to cut them because the shearing action of scissor type mechanisms really crushes the PTFE. Always follow up with brake clean when introducing small particles into your lines.
Old Sep 6, 2023 | 03:58 PM
ULTM8Z's Avatar
Yes. Same here... small cutoff wheel on a Dremel makes a nice clean cut. Just wrap the area to be cut with duct tape or masking tape.
Old Sep 7, 2023 | 08:49 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Uncle Tony just did a Youtube on this yesterday.
Old Sep 7, 2023 | 06:34 PM
m300slr's Avatar
Car: 1985 Z28
Thanks everyone! I got some PTF hose ends etc.. and plan on installing.. I figured I should finally replace the original rubber lines under the hood on my 85...
unknown_host
Sep 22, 2012 03:08 PM
Shadygrady
Mar 17, 2010 02:56 AM
bigchief
Apr 21, 2006 10:08 PM
x5finger
Carburetors
Apr 15, 2001 02:08 PM
