1985 z28 tpi
Old Oct 30, 2023 | 05:55 PM
85z28pos's Avatar
Want a title? Post!
1985 z28 tpi
Hey I’m just looking for any suggestions as to what may be going on with my 1985 Camaro z28. Currently it’s cranking and not starting it just died idling one morning. It didn’t have spark so I replaced the icm now it has spark but still won’t start. I checked the valve on the fuel rail and it’s getting fuel to the rail. Another thing I noticed is that the tach never worked and now it moves around from 4,500 rpm to 7,000rpm while cranking. I’m new to the the third gen platform I’ve don’t have any experience with them or chevys I’ve only ever had fords so any help would be appreciated thank you
Old Nov 1, 2023 | 09:27 AM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Re: 1985 z28 tpi
Sounds like you need to go through the ignition troubleshooting steps. The module in the distributor is a prime suspect on these 80's machines. Most auto parts stores can check it for you. While you're at it, ohm out the coil and make sure there is continuity through the center post of the distributor cap to the rotor contact point.
Old Nov 1, 2023 | 10:10 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: 1985 z28 tpi
It is recommended to replace the coil whenever you change the ICM. A bad coil can lead to the ICM wearing out much faster than it should.
hoonimaro.85
Dec 2, 2022 09:42 AM
harryharmer
Sep 13, 2022 02:05 PM
