1990 305 TPI Fuel Pressure Bleed Off
Old Jun 12, 2025 | 05:45 PM
TylerM27's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: 5.0 Liter 305
Hi all,
I have a 1990 Pontiac Firebird 305 TPI. I am having issues with fuel pressure. The car accelerates fine up until about 60 mph, and then stutters/ hesitates and will not accelerate. I hooked up a fuel pressure gauge, and my pressure on prime goes up to about 30-35 PSI but then bleeds to 0 PSI within a few seconds. At idle, the car sits at 35 PSI consistently. I have not hooked up the gauge when driving the car. I just changed the fuel pressure regulator and fuel injectors, and the issue continues. I am assuming this is a fuel pump issue, but I want to hear others thoughts before I start that project.
Old Jun 19, 2025 | 08:23 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: 1990 305 TPI Fuel Pressure Bleed Off
With your story it’s likely your fuel pump check valve.
Jk_Under
Feb 11, 2013 10:32 AM
gonawol83
Aug 16, 2010 01:06 AM
Eagle223usa
May 25, 2010 09:23 PM
ULTM8Z
Nov 22, 2003 05:04 PM
Keith5
Aug 8, 2002 11:09 AM
