I need a favor
Old Feb 3, 2002 | 04:01 PM
Justin Moore's Avatar
Car: 1986 Z28
I need a favor
I need someone to do me a favor. Remove the electrical connector going to the charcoal canister and see if the black wire going to it is connected to ground. I am wondering because the Hayes manual says that 12V goes to this wire but all I am getting is a ground signal when I check it. I have been through most of the wiring harness but I cannot find where it is connected to ground. Any help would be greatly appreciated.
Old Feb 3, 2002 | 08:40 PM
C. Doyle's Avatar
I checked my connector Justin and the black wire does not seem to be grounded. I measured 19.7 Ohms with my digital meter from the black wire to ground.
I can't help with voltage that may be on that wire since my battery is dead (my car is parked for the winter until the road salt is gone).
Hope this helps
Chuck
85 IROC
Old Feb 4, 2002 | 09:08 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
How are you measuring this? continuity?
Old Feb 4, 2002 | 09:10 AM
Car: 1986 Z28
Yes, continuity.
Old Feb 4, 2002 | 09:55 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
Justin,
The green / yellow wire is grounded by the ECM when a purge cycle is requested, the other wire goes to +12v via the gages fuse.
This power also goes to the port / divert solenoids on the A.I.R. system, the EGR solenoid, the shift light (on a manual tranny), the SES light, the brake / TCC switch, and can be checked at the ALDL connector pin 'F'
There is also a fusible link in the circuit. The ECM sources the 'switched ground' to the canister purge solenoid at the 24 (smaller) connector pin A3.
Hope this is of some help.
Cheers
Richard
stickychinsac
Aug 31, 2015 06:06 AM
Fbird88
Jan 18, 2002 12:45 AM
duke_mushroom
Oct 9, 2001 10:54 PM
MrTat2
Sep 9, 2001 06:28 PM
Ryan_Alswede
Aug 22, 2001 01:54 PM
