Getting code 45(not because of O2 sensor)
Old Feb 3, 2002 | 05:38 PM
Casey'91Z28's Avatar
The SES light comes on usually when I'm cruising on the freeway. It has also come on after going WOT on the freeway and when I let off it will come on. Also my milage has really decresed lately, down to 11 mpg, all around town driving though. It's not the oxygen sensor, I replaced that. It's not the thermostat I replaced the 160 with a 180. I do have one spark plug wire that is a little burnt from my headers.(Where can I buy one moroso wire?) Now I suspect it is the hypertech chip which I have heard nothing good about.(I didn't put it in the previous owner did) Would it be a good idea to replace it with the stock chip or some other chip? Please help me!
Old Feb 4, 2002 | 12:20 PM
TTT
Old Feb 4, 2002 | 12:28 PM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
If you have a bad wire, EMI noise can cause false triggering of code 45.
Also, if the MAF sees abnormally high Airflow, (removed screens) poorly designed CAI, it can cause a fuel enrichment at cruise triggering a code 45.
Is your vacuum line connected to the FPR, this again will enrich the mixture causing, a code 45.
Also a bad TPS, or a saturated charcoal canister.
Just a few things to look for.
Cheers
Richard
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
85 Jimmy
Sep 30, 2015 07:56 AM
dusterbd
Sep 29, 2015 08:40 AM
Logan Bryant
Sep 23, 2015 06:51 AM
