Can a Ford 19lb injector flow the same as a GM 22lb injector....
Old Feb 3, 2002 | 11:20 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
with the Ford injector running at a higher pressure? Like around 46 or so???? I will be using them in an 1989 L98 350 Camaro. I cant find any reasonally prices 22lb injectors......the cheap accel's go from 21 and skip 22 and go to 23
Old Feb 4, 2002 | 09:41 AM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I think someone on here said they flow the same or a little more than a 22#. I am replacing mine with them.
Someone back me up on this.
Old Feb 4, 2002 | 11:45 AM
a73camaro's Avatar
New flow = Old flow * (New pressure / Old pressure)^0.5
That is the new flow is equal to the old flow times the square root of the new pressure to old pressure ratio.
Say I double the pressure, (60 psi/30psi)^0.5 or 2^0.5, I will only increase flow by 41%
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
toronto formula
Sep 10, 2015 07:31 AM
Street Lethal
Sep 7, 2015 01:09 PM
