AFR heads, a few questions
Alright, I'm planning on getting either AFR or Canfield heads for my soon to be LT1 equipped L98. My question is what options would you recomend? Angle plug heads? Can I get either center bolt or perimeter bolt heads? Any other suggestions or thoughts about AFR vs. Canfields? Thanks.
Adam
Adam
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Definately get centerbolt heads if you're going to use the LT1 intake!!!!!!! Also get the angled plugs. No thoughts on canfield/afr debate.
Should I get the regular angle plug heads or the L98 Angle plug heads? I'm going to be getting new wires soon. Also I'm either going to go with HookerLT's or the SLP 1 3/4 inch shorties if it makes any difference. Thanks.
evilstuie
Jan 9, 2020 08:29 PM
