Air Pump And Belt Size?
I HAVE 91 Z28 WITH THE 5.7 TPI. I AM GOING TO PUT ON SOME HOOKER
COMPETITION HEADERS NEXT WEEKEND AND HAVE SOME QUESTIONS. I AM WANTING TO DO AWAY WITH THE AIR PUMP SYSTEM
AND ALSO THE A/C SYSTEM AT THE SAME TIME I DO THIS, DOES ANYONE KNOW WHAT SIZE BELT I WILL NEED TO RUN AFTER THIS IS DONE? ALSO ANY TIPS OR TRICKS WOULD BE GREATLY APPRECIATED.
THANKS,
PAUL
THANKS,
PAUL
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Its farely ez. Unless you don't want to get an AC delete pulley. The porb. is that when you remove the AC you must relocate the tesioner. I just bought the AC delete pulley. Check the tech article on this site. It gives you the proper size belt. OR get underdrive pulleys and take off the smog pump and get the AC delete pulley like I did and reuse the stock belt. It fits
. Thread
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
toronto formula
Nov 10, 2015 06:17 AM
mcquigg
Aug 13, 2015 02:26 PM
knight72
Aug 10, 2015 09:32 PM
