porting
Old Feb 17, 2002 | 11:05 PM
silverstreakII's Avatar
porting
Im considering my first intake porting job. i can get a pneumatic die grinder(rotary style) capable of 25000 rpm's. will this be enough? also, should i consider dremel brand high speed cutting tips? or should i just get a standard abrasives kit? id like to know if it will be much harder to do it with the dremel pieces, hard enough to justify the cost of the standard abrasives kit? thanks guys
Old Feb 18, 2002 | 10:42 AM
Beefy89's Avatar
A die grinder will be much faster than a Dremmel.I just used a carbide cutting tip with a long shank to get down as far as I could.The Standard Abrasives kit is great for polishing and I think it comes with a stone or two but you really won't need it.A good carbide cutter will probably cost you $25 or so, unless you know someone who works in a machine shop.Hope that helps.
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
