need help picking out 1.6 roller rockers
Old Feb 19, 2002 | 07:03 PM
72BuickGSX's Avatar
hi guys, i need some help on this, i plan on running trick flow 23 degree heads, pretty sure my pushrod is 3/8th, motor is a 89 l98 block, do i have to use the trick flow narrow rockers, they are $299 , i dont plan on using stock valuve corvers, so clearance wont be much problem i suppose if i went with cheaper rockers, but what will work ? i see the crane rockers all the time but they dont give much info on if they will fit centerbolt heads, if i could get a set for $150 instead of $300 ,is what im hopeing, allso i have heard that roller rockers have a life span of only 100 thousand miles, ? is this true,
Old Feb 19, 2002 | 07:59 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have the same setup as you TF Heads 3/8 pushrod 7.3 length centerbolts and I went with regular SBC comp pro magnums. They are small enough to fit under centerbolts. I went with PN 1302-16
Old Feb 19, 2002 | 11:00 PM
72BuickGSX's Avatar
sweet thanks man, how much did they cost ?
Old Feb 20, 2002 | 06:32 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
259
Old Feb 24, 2002 | 10:00 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
only 100,000 miles??? how far u plan on driving???
BTW id run some harland and sharp RR's. I think they just came out with a narrow body set that is lighter then the regulars. They are cheaper then crane golds too but plenty strong.
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
