Do I have a MAP Sensor?
Old Feb 24, 2002 | 08:08 PM
Drekken's Avatar
Hey I got an 88 IROC w/ a 350 TPI. My chiltons says I should have one but it doensnt know exactly where it is. I certainly dont? Could someone tell me If I do or not and where it is? A local Parts store didnt list me even having one.... Hmm Thanks!
- Tom
Old Feb 24, 2002 | 08:17 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well if your car is stock then no you do not have one. they did not use them till 90 on the tpi f-body cars. you have a maf (mass air flow) sensor mounted before the throttle body.
Old Feb 24, 2002 | 08:48 PM
Drekken's Avatar
Yep completely stock.... Well then how come the computer can throw like a code 33 which says some crap about the MAP sensor.
- Tom
Old Feb 26, 2002 | 12:15 PM
Vader's Avatar
Drekken,
Your Chitlin's manual is almost correct, and probably better than nothing at all. GM used the same DTC numbers for similar errors on different engines and fuel systems. A '33' on a TBI engine is different than a '33' on a TPI engine. A lot of the codes are used the same way. Because of the format used to display the errors, no "zeroes" can be used, since a "no flash" can't be counted as a "zero" (except on Cadillac digitals, and we won't go there right now).
For a complete listing of GM Diagnostic Trouble Codes through 1992, grab this file:
GM Error Codes.pdf
You'll need Adobe Acrobat Reader to open/view/print the file (see link below).
The '33' on your engine is for a MAF sensor that is reporting higher than expected intake air. This can be related to a TPS sensor or distributor reference pulse problem.
Old Feb 26, 2002 | 08:15 PM
Drekken's Avatar
Thanks a lot. I'm going to check out the TPS and I do think im having ignition troubles. I'm gonna do plugs and wires because I dont think Its had a tune up in like 40k. I replaced the cap and rotor like a week ago. Thanks again!
- Tom
Old Feb 26, 2002 | 08:48 PM
Drekken's Avatar
I just got one more question... I had my ignition module tested at a local Autozone.. and it tested fine. Do you think it could still be bad and cosing me some problems? Like it just needs time to start flaking out? And the HEI ? Thats the Ignition module isnt it?
Thanks!
Old Feb 27, 2002 | 12:56 AM
nblanchard's Avatar
Try replacing MAF relays on the fire wall.... usually the problem with MAF sensors... do that before replacing the MAF, since a relay is only like 20bux, where as a MAF is like 300bux...
meeklay812
Oct 1, 2015 03:46 PM
Giocio
Oct 1, 2015 12:20 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
