Fuel injectors
Old Mar 6, 2002 | 11:09 AM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
Fuel injectors
Do i need to buy a fuel pressure regulator for my 92 z28? or is there a stock one that i can use to make the psi higher? i know i need a fuel gauge. and what psi would you recommend for maximum power with the stock fuel injectors?
Old Mar 6, 2002 | 11:58 AM
Narsty91RS's Avatar
You can either buy an AFPR or make your own. I believe 46-50 PSI is the way to go. I'd get some bigger injectors if you wanna get an AFPR, you'll get better results.
Old Mar 6, 2002 | 12:05 PM
Vader's Avatar
Chi-TPI,
You already have an FPR, and it can be converted to an adjustable unit for less than $1.00.
TPI AFPR Conversion.pdf
You'll need Adobe Acrobat Reader to open/view/print the file (see link below).
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
