LT1 or SuperRam intake?
Old Mar 7, 2002 | 04:15 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Which is going to provide the best bang for the buck? Here's what I'm running now: 355, 10.1, Sportsman II heads, Mild Crane cam (don't know specs) & Edelbrock intake & runners w/ 58mm TB (yeah I know it's too big but it was on there when I got the car). I plan on doing another motor end of summer but not sure what route to go. Toying w/ the LT4 HotCam & some juice or just going w/ a real healthy cam. I'd like to go low 12's on the motor. Any input? Thanks guys!
Old Mar 7, 2002 | 05:53 PM
wataru's Avatar
Best bang for the buck is gonna be the lt1. I think the total cost is around $400, I might be wrong though. A guy on the board named John Millican can make ya one. Check with him for more info on the cost and conversion. You probably already know the cost of a superram $$$$$$$$. Very expensive.
Later Barrett
Old Mar 7, 2002 | 05:55 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Later Barrett
EXACTLY what he said... I would LOVE to go super ram, but its just waaay too high priced. Im gonna throw an lt1 intake on my 305 for the hell of it, and if I dont like it on there, Ill put it on my 406 when its done.
Old Mar 7, 2002 | 11:32 PM
superrammed's Avatar
ive got the lt1 installed i love it pretty easy swap i was gonna go super ram but the price and all the pain in the a$$ that ive heard about the install made me change my mind its suppose to be a pita to put on i didnt want to spend the weekend to change a head gasket if i blew one like i did last year go lt1 youll like it
Old Mar 8, 2002 | 08:55 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
hey ED I have a super ram on my 388. Where in timonium do you live. I'm from the owings mills area. Your car is exactly the same as mine. I recommend the super ram because you aren't gonna be turning past 6500 rpm on the street. I think you have to change the wiring harness since the LT-1 is seqential port. I may be wrong but I'm pretty sure it is. I would stick with the TPI setup, I think its great.
Old Mar 8, 2002 | 08:57 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
When a LT1 intake is converted to fit a TPI, the car retains all the orginal wiring so the computer thinks is't still TPI. A prom burn is just about required.
Old Mar 9, 2002 | 08:30 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
Hey DerFrank, I'm right off Padonia Road & my parents live up in Westminster & I have friends over in Owings Mills. Do you have a pic of your car?
As far as the LT1/SuperRam dilema goes, I was thinking the SuperRam might give my a broader power range for a street car (plus it looks cool). Cost is a factor & even though I already have a good intake base, the runners & plenum still over $700. I've talked to John about the LT1 conversion a few months ago & he said he was able to recoop all his costs by selling his LTR parts which is Real appealing to me. I'm just looking for everyones opinion so keep 'em coming!
Old Mar 10, 2002 | 12:38 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The only bad thing about the LT1 intake is the cost/time of converting it to fit a TPI engine, and the EGR valve wont fit in the back with the distributor, so that makes it not smog legal. Otherwise, its the best bang for the buck there is right now.
Me, I want to get the Holley Stealth Ram, but its not smog legal yet either.
Old Mar 10, 2002 | 02:20 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
My opinion on the MR/LT1 vs. SR "debate" is this:
If you are only planning on spinning to 6000 or so rpm, get the SR for the extra TQ down low. It will provide just as much HP as the MR up to this rpm and give you more TQ down low.
If you want to spin to 7000+ rpm, get the MR. The MR will give you more HP, but only at the price of more rpms. Higher rpm's=higher stall, deeper gears, a shortblock and valvetrain that can take the abuse, etc.
Niether is really "better", they are each just a little better suited for different objectives. Although the new LT1 intake conversion by John Millican is cheaper than the MR and SR (the SR and MR cost about the same), which throws a new twist in the "debate".
Back to your original question, I'd have to say bang for the buck goes to the LT1 conversion. Get a very healthy cam and you will hit low 12's N/A.
New2Chevy
Sep 28, 2015 12:35 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
toronto formula
Sep 10, 2015 07:31 AM
L0tuS
Sep 4, 2015 11:16 PM
