LT1 intake swap...t-stat housing location?
Old Mar 7, 2002 | 08:59 PM
Steve10's Avatar
Do you think it matters how high or low you mount it? Problems with it a little above rad outlet or below head level? With the v-belt setup the AC is right in the path to the fender, so it's going to have to route under it. I could make a bracket to hang off the rear of the AC bracket also. What about air bubbles?
Old Mar 7, 2002 | 09:45 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
As long as it's below the height of the radiator cap you'll be fine. It can't go higher then the cap or air will not escape. I always "burp" my system with the cap off and run it to operating temp.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
sreZ28
Aug 14, 2015 07:48 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
