LT1 Intake On AFR's
Old Mar 16, 2002 | 01:00 PM
Tyler-88's Avatar
LT1 Intake On AFR's
i was planing to drop an lt1 intake onto a set of afr 195's. but a very informative source told me that i might need to port the **** out of the intake just to get the ports to match. than i'll be left with no meat on the intake. has anyone used this combo, or should i go down to AFR 190's?
Old Mar 16, 2002 | 08:03 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
On the contrary, LT1 ports are bigger then stock heads. I know AFR heads are bigger then stock but how much I don't know.
Old Mar 16, 2002 | 09:09 PM
u r sofa king we tah did's Avatar
never having lined them up, but having seen both, id say it would be pretty damn close straight out of the box.
Old Mar 17, 2002 | 11:50 AM
rhuarc30's Avatar
I measured the LT1 intake vs the l98 the other day for someone else since I have them both in my garage (doing the LT1 swap on my Iroc). The lt1 intake was about 1.19 inches wide and 2.06 tall. The specified intake for the afr's is 1.28 X 2.09 (Felpro 1205). Those numbers are pretty close, and there is plenty of meat on the lt1 intake to port match that far.
John
Old Mar 17, 2002 | 07:37 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
I emailed Marc at AFR about the same thing for my car and he told me that the LT4 intake port will match the AFR 195 and the LT1 port will match the AFR 190, and by the way you can get them machined for the LT1 intake bolt pattern.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
