The great airfoil debate!!!
Old Mar 17, 2002 | 08:24 AM
JAY87GTA's Avatar
We tried a before and after with and without the airfoil on a chassis dyno today. What we found was that with the airfoil in we had to raise the fuel pressure 3lbs to get the air/fuel ratio optimal as compared to what the pressure was without it. In my opinion that is the proof that it is doing some good. I don't remember the exact numbers but I believe it was 4-5 hp and like 8-9 ftlbs. Now some people will say that is error margin on the dyno but it consistently needed 3 lbs of fuel pressure to maintain optimal a/f ratio.
Old Mar 17, 2002 | 09:01 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Sure, it has to do something since it lets the air flow better. Proof and results are always good.
Old Mar 17, 2002 | 03:11 PM
89Irocker's Avatar
airfoil
Say I just installed an airfoil in my car, do you think I need to adjust the fuel pressure or flow rate?
Old Mar 17, 2002 | 04:32 PM
JAY87GTA's Avatar
I don't know for sure. It was only like a .2 or .3 change on the a/f ratio. The car was running Vortec heads, Vortec base from SDPC, stock runners and plenum was ported somewhat. He was also running 24lbs Ford Motorsport injectors. If your a/f is really close then it probably won't hurt either way, but since we were on the dyno with all the good stuff we figured we might as well get it as perfect as possible, so we bumped the pressure. Had it running like 12.5 - 12.7 all the way through the pull, which the dyno guy said was right where it should be.
J-money
Jan 4, 2019 09:45 AM
tglennon11
Sep 23, 2015 05:30 PM
Jk_Under
Sep 8, 2015 08:13 AM
scotrans am
Sep 5, 2015 04:26 AM
tgp1990
Sep 4, 2015 06:24 AM
