LT1 intake distributor mount mod?
Old Mar 18, 2002 | 12:18 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Came up with this idea.
I bought an adjustable slip collar for an MSD distributor, the kind you use to adjust distributor height, at the Gatornationals today. It's just over 1/4 inch. It has an adjustment screw to lock on the distributor shaft.
How about brazing that onto the LT1 intakes? It'll bring it up to where it needs to be, and if brazed to the intake, eliminates the need to drill for the hold-down bolt! Also should allow for the distributor gasket. It cost me $17 out the door. Perfect fit to my GM distributor (I would hope so).
The only problem I see is that the collar has a small gap to allow for expansion/contraction. In other words, possible vapor/oil escape.The only thoght that comes to mind...gasket maker silicone? Sloppy but hey it's 1:30 in the morning!
Old Mar 18, 2002 | 02:38 AM
Blackened's Avatar
I think drilling and tapping a hole would be a MUCH EASIER operation and with MUCH LESS headaches
Old Mar 18, 2002 | 05:22 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Need to see a picture.
Old Mar 18, 2002 | 09:01 AM
dhirocz's Avatar
I'll try to get a picture. I'm not going to do it if it doesn't appear to be a good idea but I figured I'd ask anyway.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
