Need help locating TPI fuel line parts.
Old Mar 21, 2002 | 12:55 PM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Transmission: TCI 700R4
Axle/Gears: 12 bolt with 3:73's
Anyone know where I can get the 16mm. inverted flare,tubing nuts that attach to the fuel rails.I've tried G.M.(they don't sell them individually,only the actual lines.)
G.M. used those nuts to connect to the fuel filter as well,right?
I've installed a s/d tpi from a 92 Camaro into my 71 blazer.It's been running great for a year now and I'm just trying to clean up my install.I'm trying to locate the proper tubing nuts that attach to a fuel filter for a 92 Camaro.
Thanks.
Old Mar 21, 2002 | 07:07 PM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Maybe a picture will help.
Old Mar 21, 2002 | 07:18 PM
rezinn's Avatar
If you can find some please tell me where, I've had zero luck in my search.
Old Mar 21, 2002 | 07:35 PM
Doctor J's Avatar
This may help:
http://www.diy-efi.org/gmecm/compone..._fittings.html
Old Mar 21, 2002 | 07:49 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
The tool that makes the flair is also different than a standard flair tool. That tool is very expensive. It is usually cheaper to buy pre-made lines such as the ones list at the diy_efi site.
J
Old Mar 21, 2002 | 10:55 PM
Ryan 86 TA's Avatar
Try http://www.classicindustries.com/
They seem to sell every peice there is and seperatly
Old Mar 22, 2002 | 06:23 AM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Dr.J,your link helped.At least I know what the fitting is called now.
:hail:
Old Mar 22, 2002 | 09:46 PM
BlazinOR's Avatar
Re: Need help locating TPI fuel line parts.
Thanks.
You have a local hydraulic / oil filter supply nearby? That's where I got my stuff................
K5er? You know about www.coloradok5.com ? Check it out.............
Old Mar 23, 2002 | 12:07 AM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Blazin.Oh ya,I know about CK5.I'm there multiple times a day.Thanks though.I've seen your posts and have checked out your TPI'd 406 on you web page.
I've got a local industrial/auto/you need it,we'll get it type of place on it as we speak.The guy I talked to found the fitting in one of his catolagues but is having trouble finding the 16mm/1.5 thread.
The search continues.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Sanjay
Aug 12, 2015 03:41 PM
