Best power feed for heated O2
Old Apr 5, 2002 | 10:00 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
I just installed a heated O2 and wanted to know where the best place to feed it from was,have heard people use the fuel pump relay but I don't want to loose any voltage to the fuel pump,what does the MAF burnoff draw for power?could I go to this?any better ideas?
Old Apr 5, 2002 | 11:07 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
I did the fuel pump relay method and have noticed no ill effects. I don't think so many people would do it and then recomend it to others if it hurt the fp's function. From what I understand, that circut has more than enough extra current to provide the minimum amount that would be needed for a heated element like this sensor has. Other options could easily be found with a multi-meter.
Old Apr 5, 2002 | 03:49 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
I have mine feeding off the fuel pump as well on my GTA. I use a little 6-volt relay wired into the AIR select valve to close the circuit and activate it. When the ecm energizes the air select valve (causing it to divert the air to the exhaust ports when the car is in open loop), it also activates the relay which in turn closes the heated oxygen sensor circuit and lets the o2 sensor heat up. When the car goes into closed loop, it de-energizes the air select valve to divert the air to the cat. this also de-activates the relay and turns off the oxygen sensor heater.
89GTAOz
May 16, 2020 09:31 AM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
stalkier
Aug 21, 2015 01:54 AM
Kaweh
Aug 9, 2015 02:54 PM
