Swapped to TPI, but no wire for fan...how to set it up?
Old Apr 6, 2002 | 03:01 AM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
I've swapped to TPI, but the harness had no wires for the cooling fan (had a relay though). I still have my single fant TBI setup...how can I wire it up? Do I have to hook it up to the fan relay, or can I hook it up to the fuse box, ignition...what do I have to do? Thanks.
Old Apr 7, 2002 | 04:48 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
On an '86 VIN G or H, the Fan Relay wiring goes like this:
brn/wht-from FP-FAN FUSE to Throttel Kicker Relay to Coolant Fan Relay pin C.
Dk Grn-from coolant fan sw & A/C Control Head to Coolant Fan Realy pin B.
Red-from Fusable Link F to Coolant Fan Relay pin D.
Blk/Red-from Coolant Fan pin B to Coolant Fan Relay pin A.
The Coolant Fan Switch is in the block between plugs #1 & #3.
The A/C Control Head is in the A/C pressure line between the compressor and the firewall.
customblackbird
Aug 15, 2021 10:16 PM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
Fast355
Dec 2, 2016 06:33 PM
jharrison5
Aug 19, 2015 05:53 PM
