Fuel Injectors
Old Apr 7, 2002 | 01:53 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
Fuel Injectors
I recently had a problem with the electrical connection on top of the injectors, my car would chug and then i push down on one of the tops of the connections and it 'clicked' and my car doesn't chug 'as-bad' anymore. I can also move the injectors from side-to-side (they kinda turn left to right) while installed. Are they supposed to move at all?
Old Apr 7, 2002 | 05:43 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
If you look at the connector you will see a wire clip that holds the connector onto the injector. Make sure the connector is pressed down so that the clip engages the injector properly.
Don't worry about the injector "looseness". They have an O-ring at top and at the bottom to seal at the fuel rail and at the intake base. So there is normally some rotation possible. So long as no fuel is seeping you have no problem there.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
