Need correct part number for knock sensor
Old Apr 10, 2002 | 03:00 AM
HI92Z28's Avatar
Engine: stock 350 TPI
Transmission: rebuilt stock tranny, b&m shiftkit
For my 92 Z28 5.7 TPI, and friend looked up the knock sensor for me and told me that there is two knock sensor for the 5.7's so the computer said go to match up with OEM, so in my case I will need the correct one, unless I buy both of if and return the one I don't need.
And what to you torque the knock sensor to?
Old Apr 10, 2002 | 11:51 AM
HI92Z28's Avatar
Well I did a search and found this #10456549. Is this the correct part number?
Old Apr 10, 2002 | 11:52 AM
HI92Z28's Avatar
Nobody know the torque down spec is?
Or its hand tighten?
Old Apr 10, 2002 | 05:36 PM
HI92Z28's Avatar
Need help asap!
Ok I got 13lbs from the dealer and 14lbs from a friend? So with one is the correct one? Thanks..
Old Apr 10, 2002 | 08:30 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
10456549 is correct. Torque isn't that critical. It's tappered pipe thread, just make sure the threads have sealant on them & snug it in there. 15 ft lbs. no more.
Old Apr 10, 2002 | 08:42 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
According to the AC-Delco website
92' Z28 350TPI
Sensor, Knock
#213-92 AC-Delco or
#10456549 GM Corp
So yes that is the right #. As for the torque specs follow gm manual.
edit: looks like someone beat me 2 it
Old Apr 10, 2002 | 10:04 PM
HI92Z28's Avatar
Thanks guys! I will try 14-15f ft/lbs of torque.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
twest2k2
Aug 24, 2015 11:26 AM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
