PANIC! GTA wont wake up :(
Old Apr 10, 2002 | 02:56 PM
pontiac's Avatar
last autumn i drove GTA to the garage and engine stopped by itself. i tryed to restart but it didn't wake. i didn't mind about it that much because it stopped just to a right place. i closed the doors and left it there till today.
today i tryed to start it again with fresh battery. start motor works just fine, but engine wont even try. fuel pump works quite long period of time... longer than i remember... what's wrong with my ride? any typical reason why it did that? i have quarter tank of fuel and new battery. where i should start trouble shooting? i wish to have it back. snow is melting and new paint looks so good...
please help me Gurus,
-P
Old Apr 10, 2002 | 03:10 PM
TBurke's Avatar
Check for spark. Check the ignition module they die easy.
Pull off 1 plug wire and ground it to check for spark while someone is cranking the engine.
If you have spark you may jumped time.
If you don't , Work backwards to the starter to find out what went wrong.
Trust me anyone can get a Chevy running.
Old Apr 10, 2002 | 03:48 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
its probably an ignition problem
Old Apr 11, 2002 | 12:47 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
check the coil I had the same problem
Old Apr 17, 2002 | 12:02 PM
pontiac's Avatar
i finally got back to garage and i had spare plug. spark looked just fine, except the colour was yellow not blue. probably colour of the spark is not an issue
again no sign of life what so ever and fuel pump runs up to 5-10 seconds everytime i turn power on...
grrr what would be next logical thing to look at? i wish to hit the road soon...
thanks,
-P
Old Apr 17, 2002 | 01:22 PM
tpi_roc's Avatar
your fuel pump will do that
Pull a plug and see if you're flooding
Old Apr 17, 2002 | 01:57 PM
sIcK pUpPy's Avatar
Put a fuel pressure gauge to it. Sounds like your pump might have crapped out.
Old Apr 17, 2002 | 03:42 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
I havent heard a fuel pump run anymore that about 5 seconds. Check your fuel pressure definatley.
Old Apr 18, 2002 | 04:45 PM
pontiac's Avatar
1989 have somekind of theft protection system? VATS? would it be simply possible that it's activated?
for sure i don't know how does it work.
just thinking,
- P
Old Apr 23, 2002 | 12:04 PM
87ColdAirIroc-Z's Avatar
I havn't had this experience with cars, it was with my dirt bike, i had yellow spark, and no start. I put in a new plug, blue spark and it started right up.
Old Apr 23, 2002 | 05:49 PM
Blackened's Avatar
You have to be more detailed. "won't start" is not enough.
Does the motor crank when you turn the key ? Does it WANT to start but it just doesnt ? Does it just spin and nothing happens...? Pull a spark plug wire and put an old plug in it then ground it. Go crank it and look at the plug to see if it's firing...
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
