Question about Timing chain...w/in
Old Apr 13, 2002 | 01:58 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
is there a way to check if it is correct without removing the timing cover?????? As in a think Mine may be incorrectly set but zi dont want to remove the cover unless I HAVE to...
Old May 14, 2005 | 08:49 PM
Vader's Avatar
There are several methods to check the timing chain installation (valve timing) without removing the timing cover:
1. Cut a hole in the timing cover;
2. Eat lots of carrots, develop X-Ray vison, and inspect it through the cover;
3. Have someone else remove the timing cover;
4. Install a degree wheel and marker, remove the rocker cover, set up an indicator, find your cam specs, remove a plug and insert a piston stop, and check the LCA of the intake lobe.
Or, you could bite the bullet and remove the timing cover.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
