700R4 probs
Old Apr 18, 2002 | 02:58 PM
SDTADave's Avatar
700R4 probs
The 700r4 trans was rebuilt not to long ago, has shift kit and stall con(1700 1800). Question is it won't shift unless you take it to 6000 r's. Could this be the gear on the govenor, (stripped or broken) I don't want to tear it apart till I have a clue to the problem. Thanx for the help, Dave
Old Apr 18, 2002 | 03:41 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
TV cable could be out of adjustment. Governors aren't hard to change either. Rebuilt Delco governors are about $25.
Old Apr 19, 2002 | 03:40 AM
Pro Built Automatics's Avatar
Most likely the governor.
Old Apr 19, 2002 | 04:19 AM
transfixleo's Avatar
Depending on whether or not the TV Checkball is in place or not, a broken or missadjusted TV Cable could cause that. A stuck Governor could too but not the stripped gear- it just wouldn't shift. Also, and probably the most likely is a stuck TV Valve in the Valve Body. When you say shift kit, do you mean a genuine TransGo or something else. It makes a difference.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
