Cost of a swap to T56
Old Apr 25, 2002 | 06:38 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
Those of you who swapped from auto to T56, what did it end up costing you in all? Any problems after the swap? Was it worth it? I'm considering a T56 rather than rebuilding my 700. Thanks
Old Apr 25, 2002 | 06:51 PM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
So far I have paid for:
Tranny setup including clutch, mc, sc, bellhousing etc: $1300
Spohn Torque Arm w/ ds loop: $395
Console manual shifter plate: $95
Pedals: $75
That is without the rear end gears I plan on putting in, LT1 starter, miscellaneous stuff like a pilot bearing etc., and installation if you are not doing it yourself.
I will have spent about $2500-3000 on the swap. I know some people can get stuff cheaper than what I paid though.
Old Apr 25, 2002 | 06:55 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Pedals: $75
Was the torque arm and ds loop a nescessity for the swap?
Old Apr 25, 2002 | 11:41 PM
cfabe's Avatar
Heres what I've got in mine, approx prices:
t56, bellhousing, $750
lt4 pp, flywheel, hydraulics, bolts, connectors $550
mcleod disk $130
pro 5.0 shifter $180
spohn crossmember and torque arm w/ loop $395
total: $2005
You can do it without the pro 5.0, can get a cheaper clutch, can use the stock torque arm and crossmember. I got a pretty good deal on the tranny.
Old Apr 26, 2002 | 07:12 AM
u r sofa king we tah did's Avatar
my turn
1100 - tranny, bellhousing, mcleod clutch disc/pressure plate
75 - a stock LT1 flywheel
389 - spohn torque arm/crossmember
50 - factory optional hurst shifter
100 - gm master/slave cylinder kit
about 150 in wiring connectors, bolts, and fluid
probably some other little stuff i left out so around $1900
Old Apr 26, 2002 | 12:08 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Where r u guys getting these good deals on the T56s? I usually see them for about $1400. And i'm guessing theres a reason all of u just happened to get the Torque arm?
Old Apr 26, 2002 | 12:47 PM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
I forgot to add in my cost for my Pro 5.0 shifter, ****, and a Dakota Digital box to fix the speedo. Thats another $300 right there.
I am getting the Spohn Torque arm and ds loop because you need the loop for the track and I have heard nothing but good things about the torque arm.
Old Apr 26, 2002 | 02:06 PM
Make's Avatar
How about buying it new?
Has anyone asked the price of new T-56 from chevy parts dealer, i searched the net and found this.
sallee-chevrolet.t-56
The 1993-style transmission is USD1,700 and ´94-97-style is USD2,895.
Why so huge difference in price, there is 50 lb-ft difference in rated torque but still..
Just wondering if there is error on this page. or what.
And the ratios are different too
Tremec Retro-Fit T56 is USD2,295
BTW. they have nice pictures and dimensions of T-56 on their site
t-56pics
Old Apr 26, 2002 | 11:55 PM
cfabe's Avatar
Oh, and I forgot to add the dakota digital box as well (havent bought it yet). I went with the spohn torque arm for a number of reasons... My original crossmember was already modded for the t-5 and would have to be modded agian for the t-56, I didnt have the torque arm mount thingie for the transmission, and I'd heard good things about the torque arm. Now if mr. spohn could get off his *** and send me the thing already, I'd have the car back on the road instead of still sitting in the garge.
Old Apr 28, 2002 | 03:25 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
a pretty complete list
Parts I have:
Tranny (’94 Z28)….……………………………………………$1,400
Bellhousing…………………………………………………….…..included w/ tranny
Shifter…………………………………………………………....…..included w/ tranny
Lower console rubber boot…………………………..…..included w/ tranny
Slave/master cylinder………………………………………..included w/ tranny
Tranny to bellhousing bolts……………………………….included w/ tranny
Flywheel (resurfacing)……………………………………...$25
Shifter ****……………………………………………………….$10
Shifter handle (short throw)…………………………….$45
Shifter plate w/ boot…………………………………….….$50
T56 pedal assembly(’94 Z28)………………………....$30
Pressure plate to flywheel bolts………………………included w/ tranny
Total so far……………………………………………………….$1,560
Parts still needed:
Clutch/pressure plate/ throwout bearing……………….…...…….$270
Vehicle Speed Sensor(VSS)…..………………………..........…..…..….$50
VSS plug……………………………………………..……….....................….$20
4 qts auto trans fluid (Dexron III)……………………….………………..$6
Crossmember and torque arm w/front ds safety loop(Spohn)…........................................................................................$400
Transmission mount (Polyurethane)……………………………..…….$20
Roller Pilot bearing………………………………………………………….….…$15
One piece rear main seal………………………………………………….....$20
Recalibration Box(Dakota digital SGI-5)………………………..……$85
Bellhousing to engine bolts…………………………………………………$10
Flywheel to crank bolts(6)…………………………………………….…….$6
Total more to buy………………………………………………………………….$902
Total……………………………………………………………………………………$2,462
Not included in the price is the labor to get the pedals installed (trust me, it's a PITA to even attempt IMO), which I'm assuming will be $120+. Also, the price of a ministarter or one from an LT1 if I can't get mine to fit. And of course, the rear gears will have to be changed, as the 1st gear ratio on the T56 is quite a bit less than on the 700r4. SLP take-off Posi and diff. cover=$110, gears(from a friend, 3.73)=$130, installation=$200
hope this helps
Old Apr 28, 2002 | 03:38 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
97 Trans Am T56= $1200
GMPP LT4 Presure Plate& McLeod clutch Disk=$300
custom Mcleod flywheel for 2piece seal motors=$275
Hurst Shifter= $80
Master Cynlider for T56= $80
Spohn T56 crossmember= $100
Dakota Digital SGI-5= $80
Hopefully you have a T5 b/c you can reuse are your bolts.
Smile on your Face After swap= Priceless
So a grand total of $2115.00 for me.
Old Apr 28, 2002 | 06:01 PM
Saleen201's Avatar
Car: 1997 Mustang Saleen S281
LMAO!!!!!!! :hail:
Old Apr 29, 2002 | 12:30 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
the spohn torque arm with the driveshaft it not required, the T56 will bolt right to your stock torque arm. But the driveshaft loop is always a good idea, and the spohn unit will reduce wheelhop.
Old Apr 29, 2002 | 08:02 AM
jimbuck's Avatar
Mine was about $1900. Reused the clutch that I got with the tranny. Did get new shifter and just the Spoone crossmember. I have a spreadsheet with the prices and part numbers for most of the stuff. Email if you want it.
Old Apr 29, 2002 | 12:01 PM
KiLLJ0Y
Guest
Posts: n/a
what would it cost then for swap from a t-5 to a t-56?
Old Apr 29, 2002 | 11:36 PM
ScreaminDeamin85Z's Avatar
about the same thing minus the price of the pedal setup.
Old Apr 30, 2002 | 12:47 AM
BORLAZ06's Avatar
wait a min....if I order spohns T56 i dont need a torque arm and driveshaft????
Old Apr 30, 2002 | 01:41 AM
no hes just saying that you dont have to order spohns torque arm setup, the stock one bolts up to the t-56 without mods.
Old May 19, 2002 | 05:36 PM
Nestromo's Avatar
Yeah, smartass.
Old May 19, 2002 | 06:05 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
This may help
http://sethirdgen.org/t56.htm
Old May 20, 2002 | 05:57 AM
toosloz's Avatar
but you do need a different crossmember...get the spohn set up....you'll love it
AussiePr0nCar
Mar 6, 2020 04:04 PM
19irocz85
Aug 26, 2015 07:54 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
