Strongest rearaxle
Old Apr 27, 2002 | 06:40 PM
Magnus308's Avatar
Strongest rearaxle
Which one of the rearaxles are strongest the borg-warner on the camaro -89 or the other one that was mounted on later z28 camaros until -92.
Magnus
Old Apr 27, 2002 | 09:10 PM
cdogc350's Avatar
The 9 bolt borg warner is stronger.
Old Apr 28, 2002 | 12:23 PM
kevinc's Avatar
Car: 1982 Z28
The 9-bolt Borg piece is reportedly stronger, and there are far fewer known cases of them failing compared to the 10-bolt GM corporate POS.
That said, the Borg is *much* more expensive to work on and aftermarket pieces are practically non-existent. If you have one, and you're happy with it, keep it.
If you're looking to build a rear, you can address the shortcomings of the 10-bolt easily with aftermarket axles, gears, and a posi.
Free Bird
Jul 28, 2005 11:25 PM
89RsPower!
Jun 17, 2003 10:08 PM
1991Formula350
Apr 12, 2003 10:33 AM
87daddyformula
Mar 9, 2003 03:11 PM
Chris Etemadi
Oct 2, 2001 09:26 PM
