Reuse my Torque Converter?
Old Apr 30, 2002 | 02:33 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I am getting my trans rebuilt wit ha transgo shift kit this week and the guy whos rebuilding it charges 100 bucks for a new torque converter. My current torque converter only has 20K miles on it, and it was not slipping at all. BTW, my 3-4 clutches are fried, thats why i am getting my trans rebuilt. Would it be okay if I re used my current torque converter? Could I just flush all the fluid out of it?
Old Apr 30, 2002 | 11:48 AM
Joshua Leslie's Avatar
I wouldnt do it.
the converter is most likely filled with junk from the clutches, and when you fire up the engine it will all circulate back into the tranny.
for this same reason, that is why when you rebuild it, or they rebuild it, they should flush the trans cooler.
Old Apr 30, 2002 | 03:32 PM
SIMON HOLTBY's Avatar
sounds like good advice to me. I just isnt possible to thoroughly flush a TC.
Simon
Old Apr 30, 2002 | 11:02 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well, I just got the engine and tranny out earlier today and the TC still looks brand new. I havent seen any metal shavings in the fluid at all. Could I just put a water hose in the TC and let it run for a while to flush it out? I am trying to save 100 bucks if possible.
Old May 1, 2002 | 12:04 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
dont use water, have shop flush it with tranny fluid pump, call around and ask them
Old May 1, 2002 | 02:40 PM
You are obviously on a tight budget. Try filling the TC with as much ATF as possible and then pour it out through a filter (coffee filter rag etc) and see if there are any bits in there.
A garden hose has no place in flushing gearboxes, engine etc. You are having a laugh right?
Simon
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
