Clutch wont hold @ 500 HP
Old May 5, 2002 | 11:11 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What are you guys running for clutches in the same HP range as me??
My clutch just won't hold, it burns halfway down the track. I've tried the basic s/r clutches from autozone. They worked ok when I wasn't running a blower..
-- Joe
Old May 5, 2002 | 11:34 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
I'm not even sure if there is a clutch made for a T5 that will handle that kind of power. Maybe a Centerforce? I'm surprised that the tranny is holding up behind that much power. I'm willing to bet if you did get a clutch that wouldn't slip, you would end up killing that T5 on your 1-2 or 2-3 shift.
Old May 12, 2002 | 06:14 PM
Mike Forte's Avatar
Slipping Clutch
Hi Anesthes,
You'll need to upgrade to a larger disc, pressure plate. There are many styles of clutches. 500 HP is no problem if you follow the rules. It's the clutch you're using. If you have any questions e-mail me @ <mike@fortesparts.com>.
Mike Forte
Old May 12, 2002 | 08:16 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Are you Mike Forte from "fortey's parts connection" ??
Lemme know, I've looked at RAM, Hays, etc. and they recommend not using hydraulic clutch linkage. WHich is all new, so I don't feel like ripping it out and putting in a Z bar.
-- Joe
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
