Spinning from 1st to 2nd???
I had to take my 16'' rims off the back of the car today, 'cause I had stock 14'' in the front and I was tired of the car looking like a whitetrashmobile. And before you ask, I did not put the 16'' rims that I have for the front, on the front, 'cause the tires are bald and SEVERLY out of balance, and I don't have the money to have them balanced or to buy new tires. Anyway, I was on my way home and put it at 3/4 throttle from a dead stop. When it shifted from first to second, I got wheelspin. Is this normal? As far as i know, everything is stock, except for the headers. Also, it is an automatic. The tranny also jerks a bit when shifting from park to drive, and it shouldn't be the mount, 'cause that was just replaced.
Also, when I was taking off the spacers, both wheels rotated towards the front. So, would I have a one-wheel rear-end, limited slip, or true posi? Or is the only way to tell is to hammer it from a dead stop with someone watching to see if both wheels spin?
Car: 99 Formula
Axle/Gears: 342
Most likely the height of your tire is somewhat shorter with the 14" wheels, thus raising your gear ratio numerically. This probably accounted for your increased acceleration.
