Tv cable????? Fluid????????
Old May 10, 2002 | 04:27 PM
cridom's Avatar
my tranny is slipping on 3rd and 4th 2nd and 1st are ok but
should i rebuilt my tranny????
i dunno what the tv cable do cuz im veryyyyyyyy new in this and could and old fluid in the tranny causing this? or the tv cable ajustment?
please help me
how can i ajust the tv cable and change the fluid???
what could be causing the tranny to slip on 3rd and 4rth?
Old May 10, 2002 | 06:51 PM
idrag2's Avatar
The TV cable might cause this....make sure its adjusted right. If you don't know how here is a quick way. Have someone open your throttle all the way and feel the cable if it is tight then it is ok but if its loose then push the button on the cable housing and adjust it till its tight.......just my .02
Old May 10, 2002 | 07:41 PM
cridom's Avatar
thanks
i saw it today but it was like 3/4 of inch away for me plastic thing could be that causing the 3rd and 4th to slip?????
i read in haynes that you press the botton the insert the wire in the back till it cant go further and then press the gas to max
but it didnt work
Old May 11, 2002 | 07:16 AM
transfixleo's Avatar
To adjust the TV Cable skip the book method and do this: Press the 'D' shaped lock button on the adjuster and loosen the cable setting (The black housing that the metal cable is in will move forward). Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the 'D' button and pull the cable casing (the black tube) back as hard as you can (putting maximum tension on the metal cable) and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable casing so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
Old May 11, 2002 | 07:56 PM
cridom's Avatar
thanks
do u thinks this is causing my 3rd to slid?
cuz i ajusted it and 4th worked
so imm kinda happy do u think if i keep trying it will be ok or should i
rebuilt? and how much is a rebuilt?
thabks a lot i wish that i will not have to rebuilt cuz i dont have money
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
