B&M Megashifter installation, can't start car now...
Old May 13, 2002 | 01:08 PM
GoldenSwordZ28's Avatar
Ok, after installing the megashifter into the vechicle and doing everything that was said in the instructions, EXCEPT mutilate my wiring to make the N saftey switch and R backup light switch, I cannot get my car to crank, it comes on with power and all, just no cranking.... whats the deal? What did I do wrong? I even tried plugging in the wiring harness from the old shifter and shifting that into park and starting the vehicle, Still nothing Welp, any help would be appreciated, thanks!
Adam
Old May 13, 2002 | 06:26 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
U must use the supplied micro electrical switches & wire them up as per diagram. These micro swithces control the neutral start feature on the car ( keeps U from starting car in gear!) Right now your car is confused about the gear that its in so thats why it wont start.
njdaewoo
Old May 14, 2002 | 08:46 PM
pokes87iroc's Avatar
i stuck two of them wire conters that go onto a bolt that isnt removed the u shaped ones in the two end slots on each side and mines starts up fine i dont have reverse lights do u happen to have the digram and the part number for the relay my paper went missing thanks
Old May 15, 2002 | 04:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Aren't the instructions up at http://www.bmracing.com ? I'm sure if you call their tech line, they'll be glad to lend a hand.
Old May 15, 2002 | 04:38 PM
89ROC's Avatar
the wiring has to be hooked up. or you can just bypass the neutral safety switch by connecting 2 wires (green/black with the brown one) <---I think
hectre13
Dec 11, 2023 08:14 AM
specialized
Jun 18, 2022 09:26 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
drathaar907
Aug 6, 2015 04:20 PM
