Please help 700R4 Shot ?
Old May 14, 2002 | 07:01 PM
Andrew85-Z28's Avatar
Hi all,
Just bought 88 GTA w/ 700R4 and I get that awful smell like burnt trans fuid and a grinding sound when trans is in second gear and I go more than a quarter on the pedal. When I let it shift at like 1600-1700rpm, it's going smoothly. Anything higher and the thing slips and the grinding noise appears. It's doing that in 2nd only.
Any idea? TIA.
Old May 15, 2002 | 05:22 AM
Pro Built Automatics's Avatar
Give me a call on this tomorrow, as I have several questions on this? 800 7763288 M-S 10-6 PST.
Old May 16, 2002 | 07:42 PM
more info
BTW, when the car is cold (less than 10 minutes of driving), everything is fine. Anybody has a clue?
TIA
Old May 17, 2002 | 05:42 AM
ttt
Old May 17, 2002 | 02:07 PM
Check the fluid level (in park when warm) read both sides of the stick, the sides that reads the lowest is the true reading. Check the TV cable to see if it is adjusted correctly, if it needs adjustment then do it as per transfixleo's instructions. If the fluid level is fine and the fluid looks & smells ok, and the TV cable is adjusted correctly, then it sounds like the front pump is going away (losing volume due to much rotor, vane, & slide clearence), and its time for a rebuild.
Old May 17, 2002 | 08:37 PM
Thanks Pro Built, I'll check these.
Mirror Image
Oct 29, 2017 09:51 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
