Buzzing sound coming from tranny while ideling in Park
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
My tranny will make a buzzing sound when it is ideling in park, but as soon as I give it a little gas the sound goes away, when the RPM's drop back to normal it reappears. What could be causing this buzzing sound??
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
I think an excesive clearance into Torque Converter Clutch or a bearing.
A right diagnose must be made with NEW fluid at FULL mark.
You can wait the next months. If the buzzing sound increase, you can review the TCC in a shop and evaluate change it for a remanufactured part. (A new TCC is for a possible complete overhaul in the future).
Regards,
Denis V.
Regards,
Denis V.
Axle/Gears: No idea
Make a small list:
What parts/things movement changes when you give a little gas? :
(In park/neutral):
- TCC
- Bearings
- The fluid
- Oil pump
- ... You add:...
It happens in park only?. In neutral is the same or not?
Regards,
Denis V.
(In park/neutral):
- TCC
- Bearings
- The fluid
- Oil pump
- ... You add:...
Regards,
Denis V.
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
