700R4 Low/Reverse Piston
Old May 16, 2002 | 08:16 PM
Pearl89GTA's Avatar
Please help. I can't figure out what I'm doing wrong. I had no problems with disassembly. The piston doesn't want to go into it's bore. The inner seal keeps hanging up in the groove for the snap ring. Is there a trick to re-installing the piston in the case? Thanks in advance for your advice.
Russ
Old May 17, 2002 | 04:40 AM
transfixleo's Avatar
Do you have the Bracket for the Park Rod out of the case? Also, make sure that the Tang is lined up properly.
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
