rear identification HELP!!!
Old May 17, 2002 | 04:33 PM
IROCZ88's Avatar
I pulled this disc brake rear out of a TPI firebird, not sure what year and not sure if it was a 5.0 or 5.7. I want to know whether or not it is posi and if it is worth keeping. The car wasn't running so I didn't get a chance to do a burnout to tell.
One tag that was attached to the rear cover says "SPIN RESISTANCE DIFF USE APPROVED LUBRICATION
Another tag said:
P/N 10040660
RATIO 2.77
SER. NO. 10803
I'm pretty sure it is a nine bolt rear cause I counted nine bolts around the ring gear or whatever. I just want to know if it is posi.
Old May 17, 2002 | 05:06 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Spin resistant diff is posi.
Sounds like a Borg-Warner 9 bolt.
Old May 17, 2002 | 09:34 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
2.77 ratio is a 9 bolt posi and if you want a strong rear end, it's worth keeping!
Miles
www.9bolt.com
Old May 18, 2002 | 08:46 AM
IROCZ88's Avatar
I can't afford a rebuild right now. What are the chances the posi is still good and how strong are the 9-bolt posi's?
Old May 19, 2002 | 01:52 PM
OLDYELLR's Avatar
Car: '85 IROC
Most people couldn't afford to rebuild a 9-bolt since parts are rare and expensive. However, they were supposed to be stronger than the 10-bolts, so you may be in luck.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
