How to fix
Old May 22, 2002 | 12:52 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
How to fix
buying a car with an l69/700r4 combo and 110k on it. The car was in storage for 10 years and when the seller took it out it would only go in reverse and 1st gear, she said that one time it went into second but then fell back to first? Whats wrong and how could it be fixed? Ive heard it could just be a stuck throttle vavle and that sticking a shiftkit in would solve this, is this true? Please help. Thanx
Old May 22, 2002 | 01:37 PM
Pro Built Automatics's Avatar
First check the fluid level & condition of the fluid, 2nd check out the gear on the governor, it might be broke or stripped. If the fluid looks or smells bad then the clutches or band could be gone. If the gear is fine & the oil is ok, then it could possibly be a stuck TV valve.
Bubbajones_ya
Oct 25, 2015 08:01 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
