Determining rear end
Old May 30, 2002 | 02:21 PM
HenryC's Avatar
I just completed a manual swap into my firebird, and the stock 2.7 rear end gear is way too high for the poor t5, so I would like to purchase a limited slip rear end with a 3.43 gearing. However, after ordering several wrong parts during my transmission swap, I lost my confidence, and would like to be 100% sure the rear end will fit before I buy it. My question is, how do I identify my current rear end, so as to get the correct one? My Firebird is an '89 coupe, and that is the year they changed over so I know I can't just listen to people who say "Ohh you have an '89 that is an X size by 28 spline rear end". So how do I definintively tell?
-- Henry
Old May 30, 2002 | 03:08 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
On your year the only way is to count the splines.
Old May 31, 2002 | 01:54 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
You could look at the stamp on the rearend housing, usually on one of the axels, then give us the code to translate. Or if you are lucky, the tag on the diff. cover will still be there. Counting the splines is a PITA, but you just might have to.
If you are trying to figure out the Gear Ratio by itself, then you could jack the rear off of the ground (be careful), and see how many times the driveshaft turns to one rotation of a wheel. This will give you a ball park figure, but it works for seeing the difference between 2.77's and 3.23's and so on. Or last but not least, if you have to break open the rear end, divide the number of teeth on the ring gear by the number of teeth on the pinion gear, this will give an exact number. Also there is a stamp on the outer edge of the ring gear that will tell you what the ratio is. The stamp will read something like this: 11:41, 41 divided by 11=3.73.
I think thats about it. Hope this helps.
Old May 31, 2002 | 02:08 AM
87RS402's Avatar
Re: Determining rear end
Originally posted by HenryC
... so I would like to purchase a limited slip rear end with a 3.43 gearing
I'll make this one easy.
Call around to a few different wrecking yards, tell them you want a 3.42 or 3.73 posi rear for a 82-92 F-body. It's really that easy.
You don't need to worry about splines or if you have a 9 bolt or a 10 bolt since you want to buy a whole rear and not the parts to build yours into one. Don't be suprised if you have a hard time finding a 3.42 posi , 3.42 is a V-6 ratio so it's not real common to find a base engine with posi. You should consider 3.73's also, they made my T-5 livable and aren't really that bad on the highway.
Old May 31, 2002 | 06:23 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Have you checked the RPO codes on your console lid??
P.s.
I could sell ya mine!!! But I wont...
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
