Rear end gears
Old May 30, 2002 | 02:48 PM
85zcamaro's Avatar
Rear end gears
OK i have the stock rear end gears in my 85z and want to switch to 3.73's, well my questiong is what do i have to do, is it easy.. like pull out the old gears and slip in the new ones or?
Old May 30, 2002 | 04:09 PM
ede's Avatar
ede
i think it's fairly easy to do, but requires tools most people don't have. buy a gear set for your carrier then replace pinion, set pinion depth, set preload on the pinion bearings, change ring gear, check/set back lash, check contact pattern. buy a manual and don't trust some dumbass on the net. there is a fairly easy to follow article in CHP this month. also you might want to try the search feature since this comes up about every other day
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
