pinion seal
Old May 31, 2002 | 01:26 PM
Akshay's Avatar
pinion seal
My car's pinion seal leaks. Do I need any special tools (other than sockets, renches, etc.) to remove the driveshaft, pinion flange, and seal? Or can I use regular (sockets, renches, screw- drivers, etc) tools found in hardware stores.
Akshay
1989 RS 2.8 5-spd. (3.42 gears)
Old Jun 3, 2002 | 11:37 AM
ede's Avatar
ede
you'll need something to hold the pinion yoke from spinning, i made my "special tool" from some steel flat stock. mark the pinion nut depth and make a match mark so you reinstall it to the same location, then another flat of the nut or so more
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
